Post Match Warriors v Dolphins - [Round 22, 2025]
🤖 AI Summary
📝 Summary:
The thread analyses the Warriors' narrow 18-20 loss to the Dolphins, emphasizing frustration over defensive lapses in the final minutes despite a depleted squad. Key themes include divided opinions on player efforts—Roger Tuivasa-Sheck #73 received widespread praise for dominant carries while critical penalties by Dallin Watene-Zelezniak and questionable inaction from Leka Halasima #395 drew ire for contributing to the collapse. A balanced perspective #164 highlights the team's resilience given injuries to stars like Barnett and Metcalf, but ultimately criticizes late-game decision-making under pressure. User analysis #321 identifies systemic defensive failures during the Dolphins' match-winning play. Laban's season-ending injury from Kaufusi's tackle sparked outrage over the NRL's lenient suspension #385. Coach Andrew Webster faced scrutiny for conservative tactics—notably opting not to take penalty shots to extend the lead—though some defended the strategy given personnel limitations #397.
🏷️ Tags:
Performance Review, Injury Impact, Coaching Decisions
📊 Data Source: Based on ALL posts in thread (total: 431 posts) | ⏱️ Total Generation Time: 20s
Rate the game?
  • A+
  • A
  • B
  • C
  • F-
Results are only viewable after voting.
I watched Ford closely.
He runs around like a madman but a lot of it is following the ball across field and being third man in.
He must be super fit, but it would be more sensible to leave others to do their job and conserve his energy so he stops doing exhausted plays.
He keeps on finding himself to be the only supporting player when there is an offload, think he almost sprinted to the line one time? Need someone fast for those offloads
Definitely didn't pack a sad.
He had the same niggle as last week, and some time in the first half down the Phins end it cut to him getting up slowly and limping back.
Most teams also use their wingers to cart the ball up out of their back end. Can't think of many centres that make bulk yardage metres and certainly not ours, so would be odd if he had 20 carries as game plans/stock sets are pretty well pre-structured.
There's the exceptions who get used more in attack like Herbie, but more of an outlier.
I thought he was very good, when kicked to the left he was right up there, and when Roger started carving it up he was in support and made some good runs (one was epic). Don’t know whose fault was it when the left edge opened up at the end
They attacked because they had no one that could kick the goal
So why wouldn't we put a little kick in instead of taking the tackle? One less opportunity for the opposition to use the ball
I think either decisions would be fine if you execute it😂 Giving away penalties cancelled pushing them into corners…can understand not spreading the ball to avoid intercepts. It was 100% trust the defense.
If we take the 2 and drops the ball at kickoff it’d be a blow up again
Not saying thats your opinion just general thought about it
TBH the attack was the best since the sharks game? We were running back 50m without a dominant pack. Like when did we see Dallin dive in the corner…twice?
Maybe a bit more time to gel and Egan back will help icing the chances…Cape and Charnz line running practices with TMM and Boyd, Pompey line running on the right
I think they got Marata to play prop but running a bit wider to avoid getting bent?
Hope the troops return soon to lay better platforms
Halasima is our top try scorer this year with 10 so far.
Excellent effort from the youngest person in the team! Most of them are through individual brilliance showcasing his speed, power or ability in the air.
I challenge Webster to structure our attack so the wingers can keep up with his try strike rate 🙌
Okay, I accept the challenge:
IMO Ford and Clarke were the engine room throughout last night's game. The man has a V8 motor. If he is not there, a lot of work simply doesn't get done and the 'Phins roll over the top. He knew he was representing Barney and JFH last night and did not shirk the work.
  • During his 68 minutes on the park, Ford made 121 running metres from 17 runs, the 5th highest in the team. (Clarke 166, 18 runs). 1x line break. The other three were our back three though Clarke ran a few more than DWZ.
  • He made 46 tackles, a team high (Clark 36). Leka next best, made 40. For the 'Phins only Donoghoe made more - 52. Niukore made 22 as a comparison.
  • Across the 2025 NRL season, Ford is ranked 8th most penalties conceded - just below Carrigan and above Tapine.
  • His work isn't pretty, and sometimes there is a kind of unco-clumsiness that gives a penalty away but he is continually improving on that. His current average is 0.72 penalties per game.
  • With Barney and Fish out of the picture, the team absolutely needs his relentless effort. The upside is way above any liability that comes with him.
Does that help..?
I appreciate the genuine discussion.
Yes, Ford made 46 tackles and ran for 121 metres, but quantity doesn't automatically equal effectiveness. The key for me is impact, how many of those tackles actually stopped momentum? How many of those 17 runs bent the line or forced defensive adjustments? I see him as a plodder.
Being ranked 8th in penalties conceded across the whole NRL is not a good thing. Being close to guys like Carrigan or Tapine doesn’t make it better because those players offer elite value elsewhere. Ford doesn’t.
His penalties and errors cost the team field position and momentum, consistently and especially in tight games where discipline matters most.
Ford had a line break in that game, but that's an exception, not the norm. He’s not known for tackle busts, offloads, or quick plays. In fact his quick plays often end up in errors. He’s essentially a gap filler rather than having any sort of impact on the game
I’ll never knock him for his effort, but sometimes effort isn’t enough. its about execution and impact. If you're running hard but offering minimal post contact metres, and if you're tackling often but not dominating a tackle and being dragged along as a passenger, or letting offloads go, your “engine” doesn’t mean
The argument that “we need him with Barney and Fish out” is more about a lack of depth than a vote of confidence in Ford. He’s filling a gap, a gap he’s not suited for.
I just don’t see his value other than effort. I’d give others a go ahead of him.
Is that not what Webby did yesterday?? Literally a different game plan, spreading the ball on early tackles, moved CNK to centre, Capewell back to 2nd Row etc etc.
It should have worked barring the meltdown at the end.
Some what. I think the team just reacted off the back of healeys tempo, pace and offloads around the ruck, his play style encourages attack
I think we need ford atm without Barnett. I also think he offers more than the likes of Tanner who is lowkey just a lesser version of Ford.
But yes lack of impact through the middle is why we’re getting beat in the middle lately. Ford, Fish, And Tanner are the 3 of the 4 props webby prefers atm and they all have little to no impact in the carry even Marata when he’s in the middle doesn’t offer much.
Including injury’s this is the prop rotation we need imo
Fish, Afoa start Ale, Ford bench. Don’t know when Demi’s back.
Thought our backline had more shape than recent times. We haven’t stripped teams for numbers for a bit like you pointed out
I think your dislike of him maybe discolouring some of what you think he offers. He has more than double the post contact meters of JFH. In fact if he plays next week he will pass all the post contact meters JFH made in the Panthers last year. You also mention line breaks but do you really expect your props to be making many line breaks?
Is he a starting prop? Not really but having a player like him on the bench who can play big minutes and cover middle and edge makes him a useful player to have.
I only mention the line break as it was mentioned by the poster I quoted.
I think he’s a perfect bench player.
I don’t disagree at all. What I disagree with is him being applauded for a quantity of work that doesn’t impact the game.
Bunty Afoa is someone who I think is a fringe first grader, but he hits hard and has the ability to dominate a tackle. By comparison I don’t think Ford does. Bunty would produce similar output per minute played but would impact ten game more. He can bend the line, he can stop a defender.
All I’m saying is having a lot of something doesn’t equal good.
PCM is definitely a stat I like but again, does JFH offer more in other areas to impact a game? I’d say so.
I think you are overrating Bunty here. There is many a reason he has averaged less than 30 minutes ever since Webster has taken over.
Does that help..?
Ford is a hard player to tackle. He has limbs swinging and his body contorting at odd angles coupled with a crippled racehorse looking running gait.
He regularly bounces out of the first contact.
And if he wasn’t 2nd or 3rd man in on defence a lot who would be picking up the slack.
He is the ultimate 40 minute player, not starting but one long stretch after 25 minutes will do me.
NRL
NZ Warriors
Warriors NZ Warriors
18 - 20
Redcliffe Dolphins
Dolphins Redcliffe Dolphins
📍 Go Media Stadium 🌤️ Fine 📺 Channel 9, Foxtel
Rating window closed
You missed the rating window for this match
Team Logo
6.5
NZ Warriors
Team Ave Team Average
Roger Tuivasa-Sheck
8.6
Roger Tuivasa-Sheck
Best Best Performance
Charnze Nicoll-Klokstad
5.2
Lowest Needs Improvement
TEAM LIST
Taine Tuaupiki 14
6.9 (45)
Dallin Watene-Zelezniak 2
5.9 (45)
Charnze Nicoll-Klokstad 1
5.2 (45)
Adam Pompey 3
Adam Pompey
Left Centre
6.3 (45)
Roger Tuivasa-Sheck 5
8.6 (45)
Te Maire Martin 6
Te Maire Martin
Five-Eighth
6.0 (45)
Tanah Boyd 7
Tanah Boyd
Halfback
5.8 (45)
Jackson Ford 10
Jackson Ford
Right Prop
7.2 (45)
Sam Healey 9
6.7 (45)
Marata Niukore 12
5.7 (45)
Kurt Capewell 4
Kurt Capewell
Right Second Row Captain
7.3 (45)
Leka Halasima 11
Leka Halasima
Left Second Row
6.3 (45)
Erin Clark 13
7.6 (45)
Jacob Laban 15
Jacob Laban
Interchange
6.4 (45)
Freddy Lussick 16
Freddy Lussick
Interchange
6.0 (45)
Tanner Stowers-Smith 17
5.7 (45)
Eddie Ieremia-Toeava 21
Interchange Debut
6.1 (42)
Edward Kosi 18
Edward Kosi
18th Man
COACH
Andrew Webster HC
Andrew Webster
Head Coach
6.9 (45)
