Gameday Dolphins vs Warriors - [Round 11, 2025]
Dolphins
12 - 16
IN PROGRESS
Game Clock
80:00
Suncorp Stadium
17 May 2025
Warriors
Match Stats
Dolphins Warriors
2 Tries 3
2 / 2 Conversions 2 / 3
0/0 Field Goals 0/1
0/0 2P Field Goals 0/1
2 Try Assists 2
Dolphins Warriors
50% Possession 50%
8 / 33 Set Completion 6 / 32
47 Time in Opposition Half 53
1330 Metres Gained 1316
0 Dropouts 4
7 Dummy Half Runs 8
19 / 498 Kicks/Kick Metres 19 / 555
0 40/20 0
0 20/40 0
10 Offloads 4
0 1 on 1 Steals 0
2 Line Breaks 2
2 Line Break Assists 0
5 Support Play 9
Dolphins Warriors
8 Penalties (Conceded) 8
6 Set Restarts 2
10 Errors 6
Player Stats
# Dolphins T Pts TA LB TB OFF Ta MT IT Pos DR K KM M E P
1 H. Tabuai-Fidow 1 4 1 1 5 1 9 1 0 44 0 0 0m 122m 0 0
2 J. Isaako 0 4 0 0 4 2 3 0 0 30 0 0 0m 157m 1 0
3 J. Averillo 0 0 0 0 4 2 12 1 1 21 1 0 0m 83m 0 0
4 H. Farnworth 1 4 0 1 8 3 9 0 0 29 1 0 0m 157m 1 0
5 J. Bostock 0 0 0 0 3 0 2 1 0 22 1 1 18m 132m 1 0
6 K. Nikorima 0 0 1 0 0 0 22 2 0 46 0 4 66m 0m 0 1
7 I. Katoa 0 0 0 0 1 1 25 1 1 85 0 14 414m 37m 0 0
8 F. Molo 0 0 0 0 1 0 22 0 0 13 0 0 0m 96m 0 0
9 K. Donoghoe 0 0 0 0 2 1 47 2 0 64 2 0 0m 55m 1 2
10 F. Kaufusi 0 0 0 0 3 0 19 0 0 25 0 0 0m 110m 2 0
11 K. Finefeuiaki 0 0 0 0 0 0 31 6 1 16 0 0 0m 130m 1 1
12 T. Gilbert 0 0 0 0 0 0 17 3 0 4 0 0 0m 25m 0 0
13 R. Stone 0 0 0 0 0 0 30 3 2 6 0 0 0m 30m 1 3
14 H. Graham 0 0 0 0 0 0 17 1 0 57 2 0 0m 21m 0 0
15 M. Nicholls 0 0 0 0 1 0 24 4 1 9 0 0 0m 63m 0 1
16 J. Kerr 0 0 0 0 0 0 19 2 1 7 0 0 0m 40m 1 0
17 C. Lemuelu 0 0 0 0 3 0 16 2 0 9 0 0 0m 72m 1 0
# Warriors T Pts TA LB TB OFF Ta MT IT Pos DR K KM M E P
1 C. Nicoll-Klokstad 0 0 0 0 2 0 6 1 0 30 1 0 0m 149m 0 0
2 D. Watene-Zelezniak 0 0 0 0 1 0 15 2 0 11 0 0 0m 70m 0 0
3 A. Pompey 0 0 0 1 5 1 15 2 2 16 1 0 0m 73m 0 1
4 K. Capewell 1 4 0 0 2 0 19 6 0 12 1 0 0m 87m 0 0
22 R. Tuivasa-Sheck 0 0 0 0 0 1 4 0 0 24 0 0 0m 159m 1 0
6 C. Harris-Tavita 0 0 1 0 0 0 18 4 3 45 1 8 256m 41m 2 0
7 L. Metcalf 0 4 1 0 2 0 15 2 0 54 0 11 299m 41m 1 0
8 J. Fisher-Harris 0 0 0 0 2 0 36 0 1 13 0 0 0m 95m 0 2
9 W. Egan 0 0 0 0 0 0 44 5 0 119 3 0 0m 51m 0 1
10 M. Barnett 0 0 0 0 1 0 29 1 3 17 0 0 0m 126m 0 0
11 L. Halasima 0 0 0 0 2 1 38 3 1 15 0 0 0m 110m 1 1
12 M. Niukore 1 4 0 1 2 0 18 2 1 11 0 0 0m 76m 1 0
13 E. Clark 0 0 0 0 6 1 37 4 2 32 1 0 0m 138m 0 1
14 T. Martin 0 0 0 0 0 0 5 0 1 6 0 0 0m 0m 0 0
15 J. Laban 1 4 0 0 3 0 16 1 0 3 0 0 0m 17m 0 0
16 D. Vaimauga 0 0 0 0 1 0 8 0 0 5 0 0 0m 36m 0 1
20 T. Stowers-Smith 0 0 0 0 0 0 18 2 1 7 0 0 0m 47m 0 1
🤖 AI Summary
You don't have permission to generate AI summary.
Who will win?
  • Warriors 13+
  • Warriors 12-
  • Warriors JANFIN Special by 6
  • Dolphins 12-
  • Dolphins 13+
Results are only viewable after voting.
Status
Not open for further replies.
maybe the worry was more about RTS. RTS has trained all pre-season on the wing, so the transition for him back onto the side is smoother by having him on the wing as opposed to center.
Starting 13 was looking more balanced with Capewell back to 2RF, Niukore back to bench middle. That right edge has not been working on D with the Niukore/Capewell combo.
Hope this doesn't come back to bite us.
Definitely agree, but Capewell vs Herbie on paper is a heavy mismatch.
Maybe Pompey is shifting is shifting to the right and Capewell left going off NRL app lineup, which isn't as bad. Capewell can do a job on Averillo.
I also preferred Capewell to forwards. Though if it’s wet the Dolphins may be tempted to over play their hand.
I do think it is the signal that Tuaupiki is just not quite at NRL level. He has looked dangerous but hasn’t been able to capitalise on his half breaks in the way that a weeks or kini do. If you are going to be his size in first grade you need to light it up when you get the half chances. He has been close but hasn’t quite iced them.
The debate the coaches would have had with RTS coming back was plug the whole due to the injuries to our centres or put him back to the wing which is the overall plan for this year.
It's tough for Tuaupiki who has done well filling in on the wing.
We do get our preferred wingers back and will have some strong early set carries with RTS back.
To adjust a Homer Simpson quote. If we win I'll praise it, if we lose I'll criticise it until my throat/fingers get sore.
Status
NRL
Redcliffe Dolphins
Dolphins Redcliffe Dolphins
12 - 16
NZ Warriors
Warriors NZ Warriors
📍 Suncorp Stadium 👥 32,165 🌤️ Fine 📺 Foxtel
Rating window closed
You missed the rating window for this match
Team Logo
6.9
NZ Warriors
Team Ave Team Average
Leka Halasima
8.0
Leka Halasima
Best Best Performance
Te Maire Martin
6.0
Te Maire Martin
Lowest Needs Improvement
TEAM LIST
Charnze Nicoll-Klokstad 1
7.0 (2)
Dallin Watene-Zelezniak 2
6.0 (2)
Adam Pompey 3
Adam Pompey
Right Centre
6.5 (2)
Kurt Capewell 4
Kurt Capewell
Left Centre
8.0 (2)
Roger Tuivasa-Sheck 22
8.0 (2)
Chanel Harris-Tavita 6
6.5 (2)
Luke Metcalf 7
7.0 (2)
James Fisher-Harris 8
James Fisher-Harris
Right Prop Captain
7.0 (2)
Wayde Egan 9
7.0 (2)
Mitchell Barnett 10
7.0 (2)
Leka Halasima 11
Leka Halasima
Right Second Row
8.0 (2)
Marata Niukore 12
Marata Niukore
Left Second Row
6.5 (2)
Erin Clark 13
8.0 (2)
Te Maire Martin 14
Te Maire Martin
Interchange
6.0 (2)
Jacob Laban 15
Jacob Laban
Interchange
7.0 (2)
Demitric Vaimauga 16
6.0 (2)
Tanner Stowers-Smith 20
Interchange Debut
6.5 (2)
COACH
Andrew Webster HC
Andrew Webster
Head Coach
6.5 (2)
