matiunz
Watched the replay, was a try- VERY bad miss from ArtharsWhy didn’t we go upstairs on the Sam walker try
His put down wasn’t clear cut
We get it. Ads aren't what you are here for. NZWarriors.com has been up for almost 20 years and relies on ad revenue to help keep the server running.
Please add us to your ad blocker's whitelist or disable to run on our website. Alternatively, click here to upgrade your account to remove all ads.
80th minute |
22 | 14 | |
SCG 17 Apr 2022 04:00 PM |
Roosters | Warriors | |
3 | Tries | 2 |
3 / 3 | Conversions | 2 / 2 |
0 / 0 | Field Goals | 0 / 0 |
/ | Two Point Field Goals | 0 / |
51% | Posession | 49% |
8 / 28 | Set Completion | 9 / 30 |
78 | Completion Rate | 77 |
45:59 | Time in Opposition Half | 34:24 |
2064 | Metres Gained | 2061 |
1 | Dropouts | 0 |
5 | Dummy Half Runs | 3 |
19 | Kicks | 20 |
601 | Kick Metres | 805 |
0 | 40/20 | 0 |
20/40 | ||
One on One Strip | ||
3 | Line Breaks | 2 |
6 | Offloads | 4 |
Roosters | Warriors | 9 | Penalties (Conceded) | 8 |
Set Restarts | ||
8 | Errors | 12 |
Handling Errors | ||
36 | Missed Tackles | 26 |
0 | Sin Bin | 0 |
0 | Sent Off | 0 |
# | Player | T | Pts | TA | LB | TB | OFF | Ta | MT | IT | Pos | DR | K | KM | M | E | P |
1 | J.Tedesco | 0 | 0 | 0 | 0 | 5 | 2 | 1 | 0 | 0 | 25 | 0 | 1 | 11m | 155m | 0 | 1 |
2 | D.Tupou | 1 | 4 | 0 | 1 | 4 | 1 | 2 | 0 | 0 | 20 | 0 | 0 | 0m | 148m | 0 | 0 |
4 | J.Manu | 0 | 0 | 0 | 0 | 1 | 1 | 16 | 3 | 2 | 12 | 0 | 0 | 0m | 51m | 0 | 0 |
5 | K.Naiqama | 1 | 4 | 1 | 0 | 1 | 0 | 15 | 2 | 0 | 17 | 1 | 0 | 0m | 61m | 1 | 1 |
6 | S.Walker | 1 | 14 | 0 | 1 | 2 | 0 | 23 | 4 | 0 | 37 | 1 | 6 | 122m | 73m | 0 | 0 |
7 | L.Keary | 0 | 0 | 0 | 0 | 0 | 0 | 17 | 1 | 2 | 44 | 1 | 11 | 461m | 76m | 0 | 2 |
8 | J.Waerea-Hargreaves | 0 | 0 | 0 | 0 | 3 | 0 | 22 | 3 | 0 | 12 | 0 | 0 | 0m | 109m | 1 | 1 |
9 | S.Verrills | 0 | 0 | 0 | 0 | 1 | 0 | 27 | 0 | 1 | 86 | 2 | 1 | 8m | 23m | 1 | 0 |
10 | L.Collins | 0 | 0 | 0 | 0 | 0 | 0 | 30 | 4 | 0 | 16 | 0 | 0 | 0m | 112m | 0 | 1 |
11 | N.Butcher | 0 | 0 | 0 | 0 | 0 | 0 | 23 | 1 | 0 | 13 | 0 | 0 | 0m | 112m | 0 | 0 |
12 | S.Tupouniua | 0 | 0 | 0 | 0 | 3 | 1 | 28 | 6 | 0 | 14 | 0 | 0 | 0m | 113m | 2 | 1 |
13 | V.Radley | 0 | 0 | 0 | 0 | 2 | 0 | 40 | 6 | 1 | 31 | 0 | 0 | 0m | 110m | 2 | 1 |
15 | F.Baker | 0 | 0 | 1 | 0 | 0 | 0 | 19 | 1 | 0 | 8 | 0 | 0 | 0m | 50m | 0 | 0 |
16 | A.Crichton | 0 | 0 | 0 | 0 | 2 | 0 | 37 | 2 | 1 | 11 | 0 | 0 | 0m | 95m | 0 | 1 |
18 | L.Lam | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0m | 0m | 0 | 0 |
22 | D.Suluka-Fifita | 0 | 0 | 0 | 0 | 0 | 1 | 5 | 0 | 0 | 7 | 0 | 0 | 0m | 48m | 0 | 0 |
23 | J.Suaalii | 0 | 0 | 0 | 1 | 1 | 0 | 3 | 2 | 1 | 14 | 0 | 0 | 0m | 126m | 0 | 0 |
24 | D.Hutchison | 0 | 0 | 0 | 0 | 0 | 0 | 24 | 1 | 0 | 33 | 0 | 0 | 0m | 0m | 1 | 0 |
1 | R.Walsh | 0 | 6 | 1 | 0 | 7 | 0 | 5 | 0 | 0 | 29 | 0 | 4 | 67m | 124m | 3 | 1 |
2 | D.Watene-Zelezniak | 1 | 4 | 0 | 0 | 2 | 0 | 7 | 1 | 2 | 14 | 0 | 0 | 0m | 102m | 2 | 0 |
3 | J.Arthars | 0 | 0 | 0 | 0 | 1 | 0 | 15 | 1 | 2 | 12 | 0 | 1 | 22m | 58m | 1 | 2 |
4 | A.Pompey | 0 | 0 | 1 | 0 | 3 | 1 | 9 | 2 | 1 | 20 | 0 | 0 | 0m | 145m | 2 | 1 |
5 | E.Kosi | 1 | 4 | 0 | 1 | 1 | 0 | 4 | 0 | 1 | 15 | 0 | 0 | 0m | 73m | 1 | 0 |
6 | C.Harris-Tavita | 0 | 0 | 0 | 0 | 0 | 1 | 11 | 1 | 1 | 50 | 1 | 3 | 79m | 60m | 1 | 0 |
7 | S.Johnson | 0 | 0 | 0 | 0 | 1 | 0 | 11 | 4 | 2 | 47 | 0 | 12 | 636m | 31m | 0 | 0 |
8 | A.Fonua-Blake | 0 | 0 | 0 | 1 | 10 | 0 | 28 | 2 | 0 | 20 | 0 | 0 | 0m | 153m | 1 | 0 |
9 | W.Egan | 0 | 0 | 0 | 0 | 0 | 0 | 44 | 1 | 0 | 93 | 1 | 0 | 0m | 14m | 0 | 1 |
11 | E.Aitken | 0 | 0 | 0 | 0 | 2 | 1 | 30 | 2 | 0 | 15 | 0 | 0 | 0m | 88m | 0 | 0 |
12 | B.Sironen | 0 | 0 | 0 | 0 | 0 | 0 | 28 | 3 | 1 | 9 | 0 | 0 | 0m | 58m | 0 | 0 |
13 | J.Curran | 0 | 0 | 0 | 0 | 2 | 0 | 46 | 1 | 1 | 20 | 0 | 0 | 0m | 86m | 0 | 0 |
14 | K.Nikorima | 0 | 0 | 0 | 0 | 1 | 0 | 10 | 1 | 0 | 20 | 1 | 0 | 0m | 18m | 0 | 0 |
15 | B.Afoa | 0 | 0 | 0 | 0 | 2 | 0 | 27 | 0 | 0 | 7 | 0 | 0 | 0m | 56m | 0 | 2 |
16 | A.Pene | 0 | 0 | 0 | 0 | 3 | 0 | 23 | 2 | 0 | 15 | 0 | 0 | 0m | 104m | 1 | 0 |
17 | E.Katoa | 0 | 0 | 0 | 0 | 1 | 1 | 28 | 3 | 0 | 8 | 0 | 0 | 0m | 54m | 0 | 0 |
18 | T.Otukolo | 0 | 0 | 0 | 0 | 0 | 0 | 13 | 2 | 0 | 8 | 0 | 0 | 0m | 35m | 0 | 1 |
25 | P.Kepu | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0m | 0m | 0 | 0 |
Watched the replay with a bit more of a level head and looking at the controversial calls with the emotion taken out.
Tedesco professional foul in the first 10 mins was borderline, being as early as it was in the game and the speed Addin Fonua-Blake played it probably saved him- 50/50 we didn’t get
Dont think you could have awarded the Arthars try, strip wasn’t clear over Walsh losing it, would have been happy if it was awarded but pissed if it was awarded against us.
The rest of the reffing was fine except for a 5 min period around the 20-15 mins to go period.
The Addin Fonua-Blake strip call was plain wrong and shifted momentum away from us, there was then a knock on call on the last against Dallin Watene-Zelezniak that went back(but have seen similar called tbf)
The Pompey foot in the ptb was unlucky but technically correct but that was the winning of the games sadly.
Once the Roosters kicked 8 ahead our attack dried up and we weren’t good enough to come back- them getting to 8 was a little unlucky but their last no try was probably a 50/50 that went our way
A decision that had less impact on the game that I still found frustrating was the Arthars I think it was got done for holding down Tedesco.
Tedesco was down but got up pretty much straight away which is one of his strengths but it was like he kept running. If Arthars did let go Tedesco would of played the ball 3-4 metres up field instead of where he was tackled.
I have had this theoretical conversation in private before with one of my forum friends on this site but will share now in the thread that I believe in reductionism
In some academic cases circumstances are so complex that you can’t blame an outcome on on one reason and you always have to concur the outcome was due to multiple reasons.
In train accidents and workplace accidents multi factor reasons are always used as they don’t pin a tragedy on one person or one factor.
This is the correct approach as there probably were 5 or 6 reasons and real life accidents are complex.
In issues not involving life and death and where a learnings from a defeat are imperative to future long term success then hanging one person out to dry for a loss or failed project creates better actionability in the build up to the next project or next game the team plays.
It is easier and manageable to focus on fixing one or two things after a loss rather than ten learning points.
My blaming the entire loss on Walsh’s kick off is in keeping with my boarder views as a sports arm chair analyst and a analyst in the business world.
In my view and in Shaun Johnson’s that kick was the turning point because I was looking for a turning point
If I had to have a second reason would blame Aaron pene and bunty for both not running over 100 metres in a game where we had bad go forward in the middle
If you don’t believe or agree with my reductionism theory of if it doesn’t hold them Walsh deserved an 8 as overall he was good if you can get past his error
In saying that, the amount of roosters supporters that have been openly critical towards the reffing for their team has been something you don’t see from the average game with a reffing mistake here and there.Yea im a bit perplexed at the outcry all of a sudden. Non of the calls actually cost us the game. There was no guarantee we score after AFBs missed call, in reality we didn't look like scoring all game after the first try. I've seen games far worse were we've been dudded by refs but for some reason this one really rubbed people the the wrong way.
Game of two half's for me and we had our chances first half to go up by a decent margin but we couldn't capitalise. Two plays in particular come to mind - pompey failing to put his winger way and Dallin Watene-Zelezniak failing to take on his winger with a clear line.
On field reff was great, bunker made some rough calls but nothing you don't see every week.
Better team still won for me. Idk maybe im just becoming old but I dont get all this anger at the refs. We weren't good enough to win it.
Wow! Ive seen some bad takes on this site but this is right up there. There is just so much to unpack here…but the most ridiculous ones need mention.
- Reece gets a 1 because of 1 error. Yet his individual brilliance in the second half kept us in the game.
- Kodi a 7 coz he didnt make an error 😂
- Dallin Watene-Zelezniak drops a ball that leads to a try but scores 1 off Reeces brilliance so he gets a 7.
- Chanel Harris-Tavita sets up the Kosi try perfectly and was huge on defence (the Crichton stop was something else) but you rate him a 3.
- And then the kicker…brings up Kane ‘bloody’ Evans like he would have made a single bit of difference!!! In the wise words of Gus “NO NO NO!!!
That kids is why you should avoid drugsPlayers grades with comments (in case Tajhay is wondering why I didn't grade in the grading app)
1 Reece Walsh - 1 out of ten. Needs to take accountability for this loss. What was he thinking before the infamous second half kick off? I am going to drill this 1 metre inside the dead ball line to give us a great start to the second half? Why? How about a nice safe kick. He did another one later that nearly went over the side line on the full. Maybe Shaun Johnson to kick off from now on or Chanel Harris-Tavita.
2) Ed Kosi 8 out of 10. Great game
3) Pompey 10 out of 10. Best centre on the field for either team
4) Arthars 2 out ten. Stupid penalty at a critical point in the game.
5) Dallin Watene-Zelezniak - dropped the pill on the game winning try. Warmed into the match as it went on. Good try. That took some finishing. 7 out of 10.
6) Chanel Harris-Tavita - we needed a 40 20 down the stretch and he didn't step up and try. Lack of assertion means a 3 out ten. Good tackling.
7) Shaun - 4 out of ten. A turning point of the match was when he gave away a 7 tackle set in the first half with a grubber kick. He needs to weight those inch perfec.t They scored off the 7 tackle set if I recall correctly. He did not get us enough repeat sets in general. He needs to be better. He should be aiming to be the best player on the field each game. Not good enough.
8) Addin Fonua-Blake - 149 metres. 8 out of 10.
9 Egan - 7 out of ten. Stupid penalty
10) Pene - Ran for only 93 metres. We needed 150 from him tonight given how light on props we were. He ran it up like a powder puff and looked afraid of contact. I would be too but he is an NRL prop. Get into it son. He is yet to run for 100 metres this season. Should have Kept Kane Evans instead like I said all along. 1 out of ten for Pene. He didn't play badly but he needed to have the game of his life tonight instead he put in a paycheque performance and is turning into a pay cheque player.
11) Aitken 9 out of 10. Does a lot of unseen work.
12) Sironen. In tackling you talk about hard shoulders that win the collision. He had a weak shoulder tonight that let them make the advantage line each time. 4 out ten. At least no play of the ball errors.
13) Curran. Meh 5 out of ten'
14) Kodi No mistakes. 7 out of ten
15) Bunty. Only 53 metres. One of his worst outings. Didn't put his hand up enough. 2 out of ten.
16) Katoa - started off with a hard shoulder and real impact. Then he got gassed after only 3 to 4 minutes on the field. Brown's patience with him must be tested.
17 Otokulu - Good ball security. 4 out of ten. No mistakes.
Was walsh who rushed up initially and missed then Shaun Johnson who had a good shot at him but he also missed. Arthurs was the last tackler but by that time it was too late.Watched the replay, was a try- VERY bad miss from Arthars
Or the win (or was it?) against the Tigers. Worst 80 minutes I’ve ever watched.One thing I’ll take from the loss is we’re improving. Roosters are a top 4 side that know how to win. Compare this performance to the round 1 loss to the Dragons.
Ruck speed was probably the issue. We weren’t getting quick play the balls.Had a major issue with how quick the Roosters were getting off their line compared to us. Why do we struggle so much in this area compared to what seems like every other team?
Walsh is often out of position on defence, is not safe under the high ball, has stopped sniffing rounds the props, he makes some miracle plays now and then and is a great goal kicker. He a made a mistake that led to the roosters dominating us in the first ten minutes of the 2nd half which is where we lost the game. If you are rating him on his impact on the game wrighty is possibly a bit harsh but not that far off in my opinion.I rate his player rating a 3 out of 10. Was pretty shit imo. For example walshs rating is incredibly harsh. He had the bad kick off error but what else did he do to deserve 1?
Dont think Shaun singled that out as a turning point but was rightly pointing out we made too many errors that 2nd half which started right from the kick off. Dont think he implied that kick was the reason for all errors after that at all.In my view and in Shaun Johnson’s that kick was the turning point because I was looking for a turning point
Nelson Asofa Solomona can be approached from November, bearing in mind his vaccination stance would he be worth an offer? Sounding like Barnett for next year, but what position?Who are the club going to target to replace Lodge next season if he doesn’t resign. No doubt our current rotation works when he plays but seems to lose something when he dosent.
The way Covid evolves I am no longer against signing unvaccinated twits like NAS.Nelson Asofa Solomona can be approached from November, bearing in mind his vaccination stance would he be worth an offer? Sounding like Barnett for next year, but what position?
02 Apr
